22R overheats with thermostat in
Old May 3, 2007 | 06:14 PM
tnau664's Avatar
I'm back at it folks. I got 3 days after replacing headgasket and truck ran fine with no water lose or overheating problems. I put in a new thermostat and bam! within 15 minutes the temp hand started climbing. I really hoped it was a bubble and would clear when the t'stat opened, but it never did. When I shut it down the pressure was blowing out the reservoir. Anyone seen this engine run OK w/o t'stat but overheat with it in?
Thanks
T
Old May 3, 2007 | 07:07 PM
tc's Avatar
tc
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old May 3, 2007 | 08:05 PM
MMA_Alex's Avatar
a lot of aftermarket t-stats can be sticky, and not like to open. get a pot of water, and a thermometer, and test it on your stove.
Old May 3, 2007 | 08:10 PM
fthertime666's Avatar
are you sure you did'nt install it backwards?
Old May 3, 2007 | 09:19 PM
Corbit's Avatar
Also check out the Rad. It could be plugged.
Old May 4, 2007 | 07:15 AM
norcalsvx's Avatar
use the toyota t-stat on 4 crawler's page i just went through this
Old May 4, 2007 | 01:27 PM
TOYUKI's Avatar
I Would Also Recommend Checking To See If Thermostat Was In Backwards....
Old May 4, 2007 | 09:05 PM
tnau664's Avatar
Thanks for the replys. Here we go.
*Yep, installed correctly.
*New Radiator
*I'm going to drop the present t'stat into water on stove just for curiosity sake
*I just purchased a new t'stat from AutoZone that must be a 2 stage from the strange design.
*For now, I'll park the yota or use for short trips w/o the stat, then try the new stat when I can.
**I'll let you know
T
kawazx636
Oct 6, 2021 03:03 PM
buckz6319
Aug 5, 2017 03:50 AM
wberry85
May 17, 2016 05:45 PM
White Stripe
Oct 6, 2015 10:47 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
