.20 .30 .40 over ??? Any perks?
Old Feb 9, 2014 | 09:57 AM
Yodalife12's Avatar
Any diffrence on the borading ? Hp ? Torque?
Also if you run a cam around .443 would it be best to run the dual valve springs ?
Thanks
Old Feb 9, 2014 | 10:36 AM
Rule So Hard's Avatar
"Boring" your engine does increase displacement which does increase HP a very negligible amount. But its actually to restore your cylinders to roundness and a nice surface for rings to seal. As far as cams and springs. You want your springs stiff enough to close the valve as quickly as the cam lobe will allow at your maximum rpm. As lift and or duration increases the "steepness of the cam profile increases also. This means that if your springs are not stuff enough they will "float". This can cause all sorts of problems that can make your day not so fun.
Old Feb 9, 2014 | 12:50 PM
wyoming9's Avatar
Red face
Bore only enough to get the cylinders round .
Material left to bore again in 1/2 million miles
Big Cam strong new springs to make sure the valves follow the cam
rusche
Oct 2, 2025 03:10 PM
Kytowboater
Sep 17, 2015 11:17 AM
pancake_ef2
Jun 9, 2009 09:20 AM
Ava
14
Aug 27, 2003 07:22 AM
