2.4 turbo on hilux 2.8
Old Nov 29, 2010 | 10:22 PM
  #41
4runner4ever's Avatar
Have someone build it for you using universal exhaust bends and tubing.
Get a larger silencer from the scrapyard etc.
Should be a lot less expensive than a new turbo.....
Old Nov 29, 2010 | 10:25 PM
  #42
1993hiluxsr5's Avatar
omg sorry i had a retard moment there, it just so happens that there is an exhaust shop just down the road from me!, and they have a skip outside which is always full of exhaust systems , twin mufflers, quad mufflers, single muffler, all kinds of stuff, just rusting away, might go "salvage" some parts, its not stealing if its in the bin right ? lol
Old Nov 29, 2010 | 10:44 PM
  #43
There you go....
Old Nov 29, 2010 | 10:46 PM
  #44
There you go....
The only problem being is that they are all going to be the wrong shape... can you re-shape exhaust tubing with simple tools ?
Old Nov 29, 2010 | 11:45 PM
  #45
You will need a grinder and a welder for sure.
Old Nov 29, 2010 | 11:50 PM
  #46
Got em ! just need some exhaust now
Old Nov 29, 2010 | 11:55 PM
  #47
if i were to build this exhaust and fit it before i have the turbo installed how much slower would it become ? in terms of back pressure and having the wrong diameter ?
Old Nov 30, 2010 | 12:39 PM
  #48
If you do it before the turbo swap you would loose torque.
And if you keep the stock exhaust with the turbo setup it would limit top end power and cause the engine to run hot.
Old Nov 30, 2010 | 05:10 PM
  #49
Damn. That's no good. I really can't afford a whole new exhaust system and my arc welder wont weld exhaust tubing together (just melts through it).
Is there a method to using an arc welder on exhausts or will I need a tig welder ?
Thanks
Old Nov 30, 2010 | 09:40 PM
  #50
You'll need TIG or MIG for an exhaust.
I used clamp style universal pipes and bends several times, but you still need a welder sometimes for the flanges, brackets and so on.
I don't see a way to work around that....
Can't rent one for a day or two?
Old Nov 30, 2010 | 10:05 PM
  #51
Hmm im not sure i dont think so, but if i can get hold of heaps of 3" exhaust would it be possible to kind of slid peices inside eachother and clamp them together ? or would they just fall apart?
thanks for all the quick replies
Old Dec 1, 2010 | 07:37 AM
  #52
That will not work, regardless of how you do it, you will need a welder at some point. I've had 5 hilux diesels, trust me, i know for sure.
Old Dec 1, 2010 | 02:13 PM
  #53
Fair enough. Damn that sucks haha :/
Old Dec 14, 2010 | 12:02 AM
  #54
Some photo's of the turbo project.
IMG_0003.jpg?t=1292316640
IMG_0002.jpg?t=1292316796
FINALLY GOT THE DOWNPIPE!!, its literally worth its weight in gold!
IMG_0009.jpg?t=1292316939
IMG_0008.jpg?t=1292317039
IMG_0005.jpg?t=1292317108
IMG_0007.jpg?t=1292317159
The god damn exhaust still doesnt fit, it has at least 5 differnet bends and welds to get it even this close, im so fed up with it!!!.
IMG_0010.jpg?t=1292317222
Moved the Idle up solenoide.
IMG_0011.jpg?t=1292317277
Its dodgey but it works
IMG_0013.jpg?t=1292317322
Old Dec 14, 2010 | 08:28 AM
  #55
Wheelingnoob's Avatar
Getting there good work. Make sure you put a Pyromomiter (EGT) gauge on it.
Old Dec 14, 2010 | 02:28 PM
  #56
Thanks, yeah I am doing I orders one from America about 2 weeks ago but US postage sucks, so I'm still waiting, I've got all the dash in bits ready to wire it up along with my boost gauge, just have to wait
Old Dec 16, 2010 | 01:24 AM
  #57
Time to hook up the turbo's life lines (oil + water)
IMG_0014.jpg?t=1292494478
Turbo oil feed from existing feed on the block, its like toyota wanted you to fit a turbo.....hmmmm.
IMG_0018.jpg?t=1292494576
My nice new stainless steel braided hoses and 100psi oil/ water piping.
IMG_0016-1.jpg?t=1292494652
My oil return, i used a T to tap into the alternater return, its a tight fit but it should work.
IMG_0019.jpg?t=1292494794
Now for the water cooling.
IMG_0015-1.jpg?t=1292494881
IMG_0020.jpg?t=1292494927
IMG_0023-1.jpg?t=1292494961
Turbo finally fitted and bolted down, all i need to do now is get the damn exhaust to fit and get some air piping and shes good to go.
IMG_0021.jpg?t=1292495037
Old Dec 17, 2010 | 09:10 PM
  #58
truckman1966's Avatar
Jealous......
Old Dec 17, 2010 | 09:16 PM
  #59
peow130's Avatar
Yo, if you can get the smaller sticks for your arc welder, and turn the amps WAYYY down, you might be able to tack weld up an exhaust. It'd be like doing sheetmetal though.. Tack it a few times, then let it cool.
Old Dec 18, 2010 | 02:37 AM
  #60
Thanks, i got my dad to do it, as much as i hate to admit it, he's good, worked perfectly and is smooth and concistant.
Got it all finished today and started it for the 1st time in weeks, but oil is coming out the turbo turbine, not alot, but a few drops are forming :S, its worrying because i dont have the crank case breather going into the inlet, which means the oil is coming from the turbo itself its brand new !!!! better not be broken or leaking or ill die!
