1st gen: Snorkel Install - Easy?
Old Dec 18, 2012 | 12:38 PM
kingoddball's Avatar
Hey,
I have an 87 1st gen. Rough as guts.
I plan on installing a snorkel. I found some guides, but not many with useful instruction.
Can someone help with a simple guide?
My theory:
Drill hole,
Install snorkel to body,
Join the snorkel to the little pipe coming from the airbox (about 4-6" long, aiming toward the frame on the passenger side).
I have a 4Y motor and the airbox is on passenger side with a pipe going toward the frame/body.
Seems very easy, just not sure if it's correct.
I plan on rebuilding this donkey into something respectable!
Old Dec 18, 2012 | 12:45 PM
Yodaforce's Avatar
So you are wanting to fab your own kit?
Just so long you have a flexible joint to allow for engine movement, everything else is pretty straight forward (getting the pipe out and up where you want it. I have seen them made out of everything from pvc to what looked like dryer vents. Lol.
Old Dec 18, 2012 | 12:49 PM
Hahaha. nice.
I plan on buying a kit ($150). It says its a Hilux kit but meant to fit 4runners.
I thought of building one, but I do like to look of the sleeker ones.
Old Dec 18, 2012 | 12:52 PM
This is the kit I'm after, I asked the bloke if it will fit an 87, got no reply though. Very rude.
http://www.ebay.com.au/itm/ws/eBayIS...10&mfe=sidebar
Old Dec 18, 2012 | 12:53 PM
Hilux4Life's Avatar
Do you have a link to the snorkel kit you are looking at? I have yet to see one for 150.
Nevermind- you just posted it.
Old Dec 18, 2012 | 12:59 PM
Yeah, bit of a delay. I'm just not sure of the body shape differences between 87 and 89.
I'd be easy to find some pipe to fit, just if the shape has changed. Could be ugly!
Edit: All the snorkels online seem to fit 89-97. Maybe the 87 falls under a different shape?
Damn...
Old Dec 18, 2012 | 01:19 PM
This is the airbox.
Attached Thumbnails 1st gen: Snorkel Install - Easy?-image-2041552519.jpg
Old Dec 18, 2012 | 02:29 PM
rokblok's Avatar
Why not Safari snorkel? They make them for many varying body styles, so your should be covered.
http://www.safarisnorkel.com/docs/snorkel/toyota.htm
Yours is prob the one close to the bottom. The SS65 I think.
Old Dec 18, 2012 | 02:51 PM
Thanks. I was looking at those, but over $400 a pop. A little too rich for me.
Old Dec 18, 2012 | 03:59 PM
DirtyHarry460's Avatar
is it okay to have the intake be in the cab? other than the noise being annoying is it alright to have your snorkel end up in the cab?
Old Dec 18, 2012 | 04:12 PM
I don't think it would be an issue
I have never seen or heard of that before (4x4 is new to me).
How would it look/function?
Old Dec 18, 2012 | 04:23 PM
I saw some jeep guys doing that but they didn't have the tops on so it was open to the air
Old Dec 18, 2012 | 06:18 PM
Yodaforce's Avatar
Can't remember what vehicle it was but they were all designed to pull air from the cabin. Pulling air from inside is fine as long as you don't submarine it and fill up the interior (which is very possible).
Old Dec 18, 2012 | 08:52 PM
Thanks fellas. I've bought a snorkel. I'll make it fit. Am I right to assume it fits to the end of the air box? The little pipe off to the right. Then time to paint the truck!
Old Dec 18, 2012 | 09:41 PM
yotafreak1991's Avatar
yes you are correct, its designed to fit the stock box, i just did one on my buddys 3rd gen. the instructions should explain everything. if you are mechanically inclined you shouldnt have a problem. its always scarry cutting into your rig.
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
scottyg486
Jul 19, 2015 05:34 PM
noahstancik
Jul 17, 2015 05:38 PM
coryc85
Jul 6, 2015 04:07 AM
