1994 V6 Automatic Transmission Slipping?
Old 10-04-2010, 11:17 AM
Korey's Avatar
Ok, it's definitely not revving up when I let off the gas. RPM's drop immediately, but when it shifts gears, the RPM's don' drop as much as it should- maybe 1-200 rpms. Is this a symptom of a slipping trans or an electrical prob?
Forgot to mention that it has the infamous code 52.
Old 10-04-2010, 11:45 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
How big are the tires on it?
Old 10-04-2010, 12:14 PM
Korey's Avatar
Tires are 31".
Old 10-20-2010, 01:39 PM
Korey's Avatar
Turns out it wasn't even the tranny after all. The timing was way off and an adjustment cured everything. Thanks everybody for their input.
Marsheen
02-17-2016 12:29 PM
Hugh_Mann
09-16-2015 03:59 AM
Hugh_Mann
08-31-2015 04:02 AM
4runnerjunk
08-22-2015 09:06 AM
mund1011
08-16-2015 07:10 AM
Quick Reply: 1994 V6 Automatic Transmission Slipping?
