1994 toyota Pickup V6 4WD poor gas milage
Old Feb 19, 2010 | 09:54 AM
93yotaSR5's Avatar
ive changed everything on my 3vze except a fuel filter and a 02 censor. i get around 15mpg city 17 hiway
Old Feb 19, 2010 | 10:04 AM
Tofer's Avatar
Sponsor
hate to say it but 15-17mpg is what i was getting with my 3.0 5sp in my 94 on 31s and stock gears..
i am getting 14-17 mpg with my 3.0 auto with 265/75R16s and 4.56 gears.
add .4 liters of displacement if you want better gas milage.. i get upwards of 20 mpg with 35s
Old Feb 19, 2010 | 10:11 AM
kiyobrown's Avatar
My cruise didn't work and it was a vacuum leak inside the actuator. Not sure if the 87 and 94 actuators are similar. I took mine apart, sealed up the cracks in the diaphram with silicone, and put it back together. Works like new. If the light is constant it's trying to work it just can't hold a vacuum.
Old Feb 27, 2010 | 02:43 PM
arielb1's Avatar
I have a 1994 4X4 V6 manual with 119K miles. Im original owner.
I have changed air filter, plugs, dist wires and cap, fuel filter, new battery, I rebuilt the starter, changed timing belt, all seals, just completed valve cover change, regularly change oil, changed both O2 sensors. I've learned how to do this all from contributors of yotatech. I did all this to learn and keep my truck maintained.
Even after doing all this, my gas mileage is still 14mpg around city. I do have the big tires though. I have kept my truck all stock.
After that all said, now Im going to focus on getting better gas mileage. Im going to focus on what Abecedarian and TNRabbit said earlier - TPS. I will follow the writeup and see what and if this is causing my low mileage.
Old Feb 27, 2010 | 03:57 PM
  #25
buckz6319's Avatar
test your fuel pressure regulator....it gets over looked, but if it doesn't function correctly it could possibly contribute to bad fuel mileage
Signs of a Bad Fuel Pressure Regulator
* The vehicle engine runs rough and often stumbles and sputters.
* The vehicle engine will not start after ignition. Usually, this is problem is encountered in the morning when you start your vehicle. Many a times, the engine starts, but stalls shortly after starting.
* The fuel pump in the vehicle becomes noisy at times.
* A bad fuel pressure regulator can also result in fouled spark plugs.
* Last but not the least, the fuel mileage of the engine decreases noticeably
Old Feb 27, 2010 | 06:19 PM
  #26
pb4ugotobed's Avatar
Hell, and I was actually pretty excited for myself the other day after I filled up and realize i got juuuuuuuuuuuust over 15mpg (like 15.08 or something actually).
I'd NEVER expect anything near 20mpg outta this thing.
Old Feb 28, 2010 | 07:59 AM
  #27
arielb1's Avatar
Hey :} thanks for the lead. I will look into the Fuel Pressure Regulator.
I dont have any of the issues you listed other than 14mpg. I will look into the forums fo a link to what a FPR is, how to find it, test it and fix. Many thanks. If anyone has a link, please post. Many thanks. It would be helpful for me an others who have this same issue.
Old Feb 28, 2010 | 11:17 AM
  #28
buckz6319's Avatar
http://aa1car.com/ you will find the fuel testing on left rail, scroll down you will see the link along with a lot of other good stuff
Old Jun 23, 2011 | 05:51 PM
  #29
Alexdogwood's Avatar
Just to throw a wrench in things I have a 94 with only 30k original miles on it. Granted I drove all city miles but I am getting 11-12 mpg. Seriously? This thing is bone stock. O2 sensor must be good, so what the heck do I do now?
Thanks!!
Old Mar 23, 2012 | 07:34 AM
  #30
Wilfred21's Avatar
gas mileage
Originally Posted by stormin94
Don't expect 20 MPG. More like 18-19... Do a tune up on it, and check MPG after that.
Also, does your cruise light blink when you try to set it?
I have a 94 toyota pickup with 31's and when I go to use the cruise sometimes it will blink . . . I'm guessing you know what this means, and its linked to gas mileage??
Old Aug 29, 2014 | 09:50 AM
  #31
Robert 1994yota's Avatar
engine parsts
I have a 1994 Toyota pick up 4wd v6 3.0 EFI and im am looking for a part . To my knowledge it is called a fan pulley bracket it is right in front of the water pump and the engine cooling fan goes on it the bearing on the wheel is bad and I need that bracket and the tensioner replaced is there any good websites I can find those 2 things at most of all the auto parts stores do not carry the parts any suggestions ?
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
shredder4286
Oct 1, 2015 01:09 PM
Brodetski
Sep 30, 2015 11:50 PM
taraf
Sep 25, 2015 02:57 PM
