1994 4Runner 3vze power loss
Old Dec 26, 2022 | 07:45 AM
94T4R4x4's Avatar
I am having an issue with my 4Runner with the 3vze losing power at higher rpm’s. The issue is super random too but I found that if I turn the key off and then back on I will have the power back for a while until something happens and makes me lose power again. I have set timing to 10 deg with E1 and TE1 jumped, set the TPS to the FSM specifications, checked the VAFM with a meter and it is in spec, changed the fuel filter, and have no vacuum leaks. Don’t know if it matters but my 4Runner was originally auto that I manual swapped and is still running the auto ECU. Anyone have any issues similar to mine? I was thinking fuel pressure or maybe the knock sensor is picking up interference from the injector harness but I don’t get a knock sensor code. Any ideas on what my issue could be? Thanks.
94T4R4x4
Jul 26, 2022 07:06 PM
Muxumus
Mar 15, 2018 09:58 AM
Kolton5543
Nov 7, 2017 04:22 AM
Jeeph8R
May 22, 2012 06:55 AM
mswift
Feb 3, 2010 10:03 AM
