1992 pickup transmission removal question
Old Oct 24, 2012 | 05:10 AM
Josh_Br's Avatar
Hello,
I have an opportunity to buy a 1992 extended cab Toyota pickup for a pretty cheap price. It has the V6 engine and automatic transmission. The transmission has issues and needs work or replaced.
I've bought "mechanics special" vehicles in the past, and have done a bit of this sort of work, but never on a Toyota. I am wondering if anyone has removed the tranny from one of these trucks, and if it is much worse (if at all) than removing the tranny from any other truck or Jeep.
One specific question I have is whether the bolts that attach the bellhousing to the block are reasonably accessible or not.
Any thoughts and info are appreciated. Thank you!
Old Oct 24, 2012 | 05:39 AM
vasinvictor's Avatar
Mostly just like any other transmission.
Pro tip here: unbolt the crossmember and lower the tailshaft down a bit to access the top bolts on the transmission. Use about 3' of 1/2" extensions and go right over the top of the trans to get at them.
Old Oct 24, 2012 | 06:01 AM
Josh_Br's Avatar
Sounds good, thank you!
Hatch man
Aug 25, 2021 12:54 PM
GreenLion
Jun 7, 2021 10:49 AM
94whiterunner
Sep 22, 2015 07:25 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Lowviz
Jul 22, 2002 10:52 PM
