1992 4Runner won’t stay idling
Old Feb 7, 2022 | 05:16 PM
Zacattacker's Avatar
Hello, I have a 1992 4Runner with the 3.0 in it (I know not the best motor) but when I bought it I was told it had to have a fuel problem. Well that’s not the case from what I’ve seen. I have checked the EFI relay and it seems ok and operational. The mass air flow sensor has been replaced. Only problem I could find physically is that the egr control module had all the ports broken off it. But I don’t think that would make it not want to idle. Any help would be great.
Old Feb 8, 2022 | 12:05 PM
2ToyGuy's Avatar
Actually, it would. Not just because all the vacuum lines are now leaking, but the EGR valve, if not functioning properly, can do that. You should also check the tube that feeds from the EGR valve into the Throttle Body. If that's clogged, and they tend to, it can cause you lots of troubles.
Did you check the o-ring on the Idle Adjust Screw? If it's cracked or broken off, that can cause some idle problems.
Is the TPS properly adjusted? If it's Idle contacts aren't making properly, it can give wrong information to the ECU.
Good luck! I hope something in my rambling is some help...
​​​​​​​Pat☺
townending
Sep 29, 2017 01:09 PM
aurastephen
Nov 27, 2011 03:02 PM
finny
Jun 2, 2007 11:27 AM
FCRunner
Nov 16, 2005 06:52 AM
93cagedyota
Apr 8, 2005 02:31 PM
