1992 3.0l v6 stalls on engagement or at 11-15mph
Old Nov 15, 2011 | 02:22 AM
MIKE I's Avatar
Hi all, newby here needing help. I am helping my dad with a 1992 Toyota Winnebago Warrior. We just finished with a new timing belt, idler pulleys and water pump. The engine runs well, smooth and lots of power. If you put the trans in manual first the truck runs fine. If you place the truck in drive or man2 it will stall.
Occasionally (mostly cold) it will allow you to shift into drive, but as soon as you hit 11-15 mph the engine shuts off. It will restart but the same thing happens every time. As it warms it will stall as soon as you shift out of park.
I have seen a few cases of torque converter clutches failing, but there is no lugging when this happens, it is like someone intentionally shut it off. Especially when driving, there is no feel of second gear engagement, just shuts off. Any help would be greatly appreciated.
Old Nov 15, 2011 | 06:52 AM
Marc's Avatar
welcome. If you short out the diagnostic terminal it might flash an error code.
Both the check engine light and the I think o/d light give out codes.
Someone will correct me and/or provide more info.
Old Nov 15, 2011 | 10:23 AM
skypilot's Avatar
You may have pinched some wires in all that work. Go back over every panel and every place you stuck something and look for broken wires and grounds, particularly the one on the back of the engine.
Old Nov 16, 2011 | 04:20 PM
MIKE I's Avatar
We have been over the timing belt repair a couple of times and haven't found any pinched wires. Very odd situation. I'll try pulling codes.
Old Nov 17, 2011 | 01:13 AM
TNRabbit's Avatar
Check for ECU codes now to avoid a lot of unecessary work.
skoob
Oct 15, 2015 03:23 PM
Rusted Rooster
Nov 17, 2010 05:37 PM
Fink
Jan 30, 2010 03:40 PM
ragz
Jan 9, 2007 04:48 PM
BlackFlag
Mar 24, 2006 01:36 PM
