1991 toyota pickup
Old Jan 16, 2016 | 12:18 PM
macattack66's Avatar
1991 toyota pickup
This truck has a v-6 and the problem it's having is when I check the oil the engines idles down and runs rough
Old Jan 16, 2016 | 07:07 PM
Chaser Johndoe's Avatar
you dont check oil with the engine running.
Old Jan 17, 2016 | 02:02 AM
wyoming9's Avatar
Red face
Why not ??
I do it all the time.
Depends just what your checking it for.
Old Jan 17, 2016 | 04:07 PM
wyoming9 you smarty pants.
Old Jan 17, 2016 | 05:58 PM
I realize you don't check oil with engine running we were trying to look for shirts on why its running rough just happens my son pulled dipstick out and it cut off we tried it again and same thing happened
Old Jan 18, 2016 | 06:13 AM
MudHippy's Avatar
First you need to make sure it's not that he's bumping the spark plug wires while pulling the dipstick. Or possibly rotating the distributor, if it's loose enough. It sounds like you've probably got some kind of ignition/plug wire issue. Less likely, but like I say possibly, timing.
Old Jan 18, 2016 | 05:00 PM
Punchy's Avatar
Dirty or bad PCV.
Also when you pull the dipstick you break the seal and air flows through the crank case in into the intake (the hose on the drivers side valve cover) bypass the AFM.
If the PCV is bad then it lets more air to bypass the AFM.
Old Jan 18, 2016 | 11:26 PM
Terrys87's Avatar
One way I check for plug wire issues is in a dark shop or dark alley, with the motor running, look under the hood. I have seen several pretty blue sparks popping around where plug wires have been compromised.
Chuckwild
Nov 19, 2015 03:03 PM
Runnin13s
Nov 5, 2015 07:45 PM
allkine
Nov 4, 2015 01:32 AM
bennyt4130
Nov 3, 2015 08:44 AM
tsh2014
Oct 28, 2015 11:48 AM
