1990 manual trans with 1994 22RE motor, what is needed
Old Aug 3, 2021 | 02:26 AM
Drewscharlow's Avatar
Hey guys, I am swapping a 1994 22RE motor (used to be paired to an automatic) into my truck with a 1990 5 speed manual trans. I am wondering what all I need in order to do this? The motor is coming out of a complete donor truck so I will be taking all of the wiring harness/ecu but I want to make sure the trans will bolt up to the motor no problem. Also, will the flywheel out of my 1990 motor work for the 1994 motor? The 1994 motor came out of a truck with an automatic. Thanks in advance for any and all help!
Old Aug 3, 2021 | 04:31 AM
wyoming9's Avatar
Red face
Both engines are 22R or 22RE correct then things will bolt right up to your .
To make this easy use the engine harness and ECU from your 5 speed you might have to swap some sensors as well when the new engine goes in nothing electrical should be on.You would need to look at both EWD`s to see if the igniter and distributor wiring is the same if your not sure use the 1990 igniter and distributor
Myself new flywheel bolts cut flywheel and complete new clutch kit unless the clutch was new last week.
if your going to try dropping the engine in with the transmission installed you want at least three people two on the bottom and one to raise and lower it can be done alone but it takes forever right side lower left side back to the right repeat for a very long time.
Best of Luck.
Old Aug 3, 2021 | 06:16 AM
rattlewagon's Avatar
Make sure to put a pilot bearing in the donor motor if it came from an automatic.
Old Aug 3, 2021 | 06:53 AM
wyoming9's Avatar
Red face
Since they seem to come with the better clutch kits then I sometimes forget the simple.
fierohink
Feb 15, 2015 11:38 AM
Paul199
03+ 4Runner/GX470, & 05+ Tacomas (Build-Up Section)
13
Feb 5, 2013 10:47 PM
Ruckus
Engine Swaps
Mar 8, 2010 06:18 PM
doubledizzle
Jan 11, 2008 06:06 PM
