1990 3.0 tps stalling engine
Old Jan 21, 2021 | 10:06 AM
Justin Rittinghouse's Avatar
Ok guys if search and found about adjusting the tps and so on my problem is my tps went bad and the truck won’t idle just stalls out and tripped the 41 code for tps. Fast forward put on me tps and does the same. If I unplug it it will run but runs rough. As soon as I plug the tps in within 5-10 seconds the truck stalls regardless of the tps position. Tried disconnecting battery to clear codes all a no go. It’s used as a rock crawler and was running fine then suddenly had this issue it was a pain just to keep it running to get it back on the trailer. Where do I go from here to get this resolved
KODE
May 16, 2019 12:56 AM
95blackToy
Jul 16, 2010 05:44 PM
elk4
Feb 24, 2009 07:51 AM
DupermanDave
Jan 5, 2009 02:17 PM
