1990 22re pickup 2wd motor oil ?
Old Feb 26, 2018 | 04:22 PM
shafner30's Avatar
so what is the recommended conventional oil for a 1990 22re 2wd in California
5w-30 ?
10w-30?
10w-40?
let me know thanks
Old Feb 26, 2018 | 05:30 PM
jakey poo's Avatar
Search is your friend
Old Feb 26, 2018 | 05:38 PM
muddpigg's Avatar
Seems like the better question would be. Should I run an oil with higher zinc content?
or what is best oil filter for the money?
To you question loads of thoughts and ideas on the subject. Do some research as mentioned.
Old Feb 26, 2018 | 07:02 PM
old87yota's Avatar
What part of California do you live in?
California is a large state. The temperatures can get quite cold in the Northern part of the state, while the Southern part stays warm year around.
I personally run conventional 10W-30 oil in my truck, with an OEM Toyota oil filter.
Once you start searching, you will find many different opinions on the subject.
Here is what my Owner's Manual says:
The back cover of the manual says, "Use SAE 10W-30 if normal temperatures are above 0° F (-18°C). For other viscosity recommendations, see page 108 [shown above]"
Old Feb 27, 2018 | 02:19 PM
shafner30's Avatar
I live in the bay area
Santa Rosa ca to be exact
shafner30
Feb 19, 2017 06:26 AM
shafner30
Feb 16, 2015 04:59 AM
199022re
Oct 27, 2014 02:50 PM
lomaxxx1337
Dec 1, 2013 04:57 PM
lomaxxx1337
Nov 23, 2013 11:45 PM
