1989 toyota pickup 4x4
Old Aug 2, 2010 | 08:43 AM
t-rav's Avatar
hello so i have a question with my truck on some noises etc... my drive shaft keeps making noises because my u-joints keep going out in a period of about 3weeks.. i have about a 4in body lift and when i turn my truck there is like a weird clicking noise in my rear end that wont go away till i straighten my truck out.. anyways everytime i replace my u-joint the noise goes away even when i start to coast etc.. but after about 3weeks i cant coast or shift without a loud clunking noise which is when i u-joint goes out again...
anyways thanks for all the help
Old Aug 2, 2010 | 02:23 PM
stackedyoda's Avatar
is there a spool or welded spider gears in the back
Old Aug 2, 2010 | 02:29 PM
rattlewagon's Avatar
Check your drive shaft angles and make sure that your shaft is not bent. There is something seriously wrong if your going through a u joint every 3 weeks.
Old Aug 2, 2010 | 03:51 PM
t-rav's Avatar
not sure what a spool or welded spider gears are and ask for the angle of the drive shaft its at a pretty good slant
Old Aug 2, 2010 | 04:00 PM
Tofer's Avatar
Sponsor
way to test if you have a spool or welded rear end.
find a parking lot.
come to a stop
turn the steering wheel as hard as it can to either left or the right
give it gas.
what does the inside rear tire do? make all kinds of churping sounds? its welded or spooled. make all kinda of popping / ratching sounds? its locked, do nothing? its open
Weidle
Jan 21, 2019 05:39 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
bprice0077
Jun 25, 2015 07:36 AM
Krash
10
Jul 13, 2002 09:21 PM
