1988 toyota truck 3.0 4x4 not starting
Old May 22, 2007 | 03:50 PM
toyota 1988's Avatar
well ive tried, the fuel pump is not cutting on so i take the old fuel pump that still works and hook it up to the gas line and run wires to the batt and try to start it up ( nothing) Ive took the timing chain cover off it is still in good condition, the fuel pump is not cutting on( it has a new one and the old one still works, there seems to be corrosion in the computer. I thought it was a gas problem all alone, well it was getting pleny of gas running it straight through a line. Please help, i have mechanic skills but right now im stuck on the issue its giving me. Thankyou.
Old May 22, 2007 | 06:55 PM
1994runner's Avatar
Check for injector pulse. They should have power at all times and the computer will pulse the ground to fire them. You can use a standard test light for this by hooking it to power once you know which are the gound wires or get a "noid" light set cheap from a good parts store that plugs in place of the injector. Power with no ground would be wiring or ecu.
matrad
Aug 26, 2024 08:21 AM
JF9243176
Oct 8, 2017 04:21 AM
JF9243176
Jun 24, 2015 04:53 AM
HALMAN
Jun 14, 2002 09:02 PM
