1988 toyota, revs wierd.
Old Aug 4, 2011 | 03:23 PM
Leonide's Avatar
i have a July built 1988 toyota truck, single cab 4x4. it's a 22RE motor.
when i rev it, the truck doesn't go back down to idle immediately after letting off the pedal... it sticks at the RPM's it revved to for a few seconds, and revs down slowly. could engine gunk in the Intake make the butterfly in the throttle body stick? if not, what causes this?
also, same issue, i hit the clutch to change gears (it's a 5 speed), the engine revs up a bit, same symptoms as neutral revving.
video of what it's doing: http://www.youtube.com/watch?v=zrn44YXE7-Q
i dunno if that whistling noise is the truck or not... most likely not... probably just a bird. i don't hear it that clearly when i sit in it.
mskalmus
May 28, 2017 07:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
