1988 3.0 timing belt
Old Jun 22, 2008 | 04:18 AM
nolimit's Avatar
Help I have rebuilt this motor and trying to install timing belt. I line up the cam pulleys as directed and #1 cylinder is tdc but after 2 complete rotations I'm about 2 teeth off on the cam pulley notches lining up. Any suggestions.
Old Jun 22, 2008 | 08:03 AM
76ANTHONY's Avatar
try lining it up 2 teeth off then when you rotate it it will land perfect
Old Jun 22, 2008 | 10:20 AM
scope103's Avatar
...but after 2 complete rotations I'm about 2 teeth off on the cam pulley notches lining up.
Just to be sure: Remember that the mark on the belt "moves" with each complete revolution of the belt. It won't line up again for, oh, 30 revolutions.
I assume you are turning the crank two revolutions (back to TDC), and then the cam pulley doesn't line up with the mark on the head. You're not getting the slack taken up when you put it on; as suggested, you can try "installing" it off by two teeth so that it will end up in the correct place.
Old Jun 23, 2008 | 06:03 AM
nolimit's Avatar
Thanks for your help. I have it worked out now.
Charecter1
Nov 6, 2023 10:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
