1988 3.0 the same as 1994 3.0?
o ya, the 88-92 3.0s were essentiall the same and hte 93-95 3.0s were the same. you would be able to get it in, but there will be a lot less 'crap' in the engine bay. go for it. You also wont have any problems with the HG since the early 3.0s werent prone to failing.
they also had about 10 less hp
sweet. looking here http://www.top4runners.com/ja/runhist21994.html it appears the biggest difference is an auto tensioner on the timing belt
Ive come across a few differences when buying spares for my 90 model, but mine has a replacement engine so i don't know what year it is.
I know the knock sensor is different, and on the dizzy to there can be differences with the wiring loom that comes out of it.
The 1988 V6 was a stand alone engine. The mounts on the block are drilled and tapped in a different place. My assumtion is that they didn't want to create new frame mounts for the new v6 motor, and just left the 22R mounts there. An 88 engine will NOT bolt into any year but and 88. The mount bosses are not even there to drill and tap to be able to install the engine. Major PITA. You CAN go from a 94 truck into an 88, but you have to drill and tap the mount bosses.
**4runner was sorta correct, the 89-92.5 long blocks are the same, as are the 92.6-95 long blocks. In 92.5, Toyota switched to the hydraulic style tensioner, which required an extra hole be drilled in the Pass side head. The tensioners, fan support, and fan assemlies are all different between 89-92.5, and 92.5-95.
So, to answer your question, NO you cannot use the engine from the 88 in your 94.
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
Aug 3, 2015 07:14 PM
i hope i get to where you are someday!
