1987 22RE Winding Sound....power steering pump? +++
Old Mar 6, 2018 | 12:08 PM
GrimWolf's Avatar
Question 1987 22RE Winding Sound....power steering pump? +++
So I have been getting this winding sound for a couple of days.....I had the same sort of sound years ago with an old Chevy S-10 and then the power steering pump went out.
Also, there is a high pitch sound when revved up that may be part of the same issue or something else. Any thoughts would be greatly appreciated. See video for what I'm talking about.
Old Mar 6, 2018 | 02:11 PM
old87yota's Avatar
It is hard to tell exactly what it is without being there myself. The lower-pitched noise does sound like a power steering pump.
Does the noise change when you turn the steering wheel??
Next, I would remove the power steering belt and start the truck up again.
It is perfectly fine to do this because the power steering is the only thing being driven from that belt. The water pump, alternator, and air conditioning run off of different belts.
If the noise(s) are gone, they are coming from that belt circuit (power steering pump, idler pulley, crankshaft pulley, the belt itself). Inspect the components while the belt is off. Check the idler pulley for smooth operation and make sure there is no play in the bearing. Also check the condition of the belt too. The belts I replaced a few years ago sounded like a bearing going bad when we had high humidity or heavy rain.
Old Mar 6, 2018 | 02:17 PM
GrimWolf's Avatar
Okay I'll give that a shot and see if the sounds persist. Thank you!
Old Mar 6, 2018 | 02:46 PM
GrimWolf's Avatar
GO figure......the sounds have mysteriously disappeared. Ugh. I guess I'll wait for it to happen again.
Old Mar 9, 2018 | 10:16 PM
DIRT8IKE's Avatar
I had this problem when I think the PO of mine put regular Power Steering Fluid in, instead of the ATF/Dexron. Replacing all the fluid in the system and bleeding it fixed the sound right up so if it comes up again check that out next maybe
Old Mar 10, 2018 | 08:19 AM
RAD4Runner's Avatar
Hopefully it's just the idler pulley bearing... just replaced mine for a few bucks (here)
Old Mar 10, 2018 | 12:24 PM
old87yota's Avatar
^^ This is definitely worth looking at, even if the noise has gone away.
Sometimes the bearing in the idler pulley can make little to no noise when going bad and then seize up.
You want the bearing to be easy to spin and feel smooth (as shown in 22RE Performance's video in the thread RAD4Runner posted) and have basically zero side-to-side play or wobble.
Last edited by old87yota; Mar 10, 2018 at 12:27 PM. Reason: Added more information as usual.
Tank8265
Jun 6, 2010 08:09 PM
516593812
Nov 21, 2009 06:46 PM
SteveMars
Feb 24, 2009 05:07 PM
mrmojorisinphan
Nov 29, 2005 06:05 PM
