1986 Toyota 4 x 4 PU Horn not working
Old Dec 14, 2021 | 11:21 AM
plsrm's Avatar
My 1986 Toyota 4 X 4 PU horn does not work though I have tested the horn (OK) and replaced the both the Brass ring and Brass pin
in the steering wheel along with the 10 amp horn/hazard fuse on the inside engine compartment on the passenger side (Hazards work).
The fuse box located on the driver's side inside cab has no horn relay switch like I saw on you tube (Part 86550-20070). I called the
dealerships an they can not find a horn relay switch but say there may be a circuit breaker which you should reset somewhere under
the dash. Where is it? Any ideas other than take it to an auto shop that has electric mechanics. Thanks.
Old Dec 14, 2021 | 02:46 PM
RAD4Runner's Avatar
There is no horn relay on the 1986. Here's how it works and how to troubleshoot:
https://www.yotatech.com/forums/f116.../#post52381275
Keywords: How Horn Works, Horn Troubleshooting
grue
Nov 2, 2021 10:41 PM
stevec8720
Sep 9, 2013 07:18 AM
myyota
Jan 20, 2007 03:18 PM
89red4x4yota
Jan 9, 2007 04:26 PM
sdstud212001
Oct 31, 2006 10:07 AM
