1986 Restoration
Old Jan 20, 2022 | 07:17 AM
Boogeyman's Avatar
1986 Restoration
I recently purchased a 1986 p/u with 22RE. The truck was pretty well optioned from the factory so I'm happy with everything. Just want to get it looking new again. Im having trouble trying to locate body panels. Specifically the ones pictured. I've searched the internet and the forum for these items and it seems most of the websites do not work anymore. So I'm asking for help now. TIA
I just need the lower part that the license plate mounts to.
Old Jan 20, 2022 | 07:54 AM
slacker's Avatar
not available new ... you'll have to make em yourself , or have them made , or find good used ones
Old Jan 20, 2022 | 09:34 AM
Boogeyman's Avatar
That's what I was afraid of 😖😖. Time to go see the fabricator!
Old Jan 20, 2022 | 12:42 PM
Blackdoodle's Avatar
I think you would have to replace the whole bed
Old Jan 20, 2022 | 01:48 PM
slacker's Avatar
Id try hammer them out first ...
Old Jan 20, 2022 | 04:31 PM
JoeS's Avatar
The area behind that crunched sheet metal is wipe open. I get small dents there all the time. I use the wood end of a ball peen hammer applied to the sheet metal and hammer the steel head end. They work right out. Yours has a tight crease but most of that will pound out and if persistent trying smaller tolls, then most for crease to. Some light bondo and good to go.
Old Jan 21, 2022 | 03:48 PM
Nervo19's Avatar
It's a little worse than mine was. I drilled a hole and used an L shaped allen wrench to pull it and also did some hammering. I did it a long time ago and it was the first bodywork I ever did. Fill with fiberglass Bondo and top with lesss than 1/4" of Bondo. I use Rage brand instead of Bondo. It was done about 2014 and I forget which side.
I found a pic on my build thread. Passenger side. I posted pictures in 2014 but the plates say 2013 so I assume I did it in 2012.
Wyatt Pierce
May 17, 2020 06:21 AM
jslone
Jan 23, 2013 02:35 PM
Heleto
Jan 7, 2013 02:45 PM
