15deg Adv, Code 26
Old Mar 25, 2006 | 07:29 AM
jandk2005's Avatar
15deg Adv, Code 26
So basically everything is back running good....... except now i got the CEL on....Ran it to work, and it came on....Im running 15 deg BTDC, checked the codes 26, running too rich....... how on earth can i run 15 deg BTDC and STILL run rich? at 15 deg its a WHOLE lot more peppy than at 10, at 10 its super doggy......... anyone wanna chime in? im thinking about going with a new Water Temp Sensor, see if that helps, only 21$ and if i remember correctly, when i put it back together, a coolant leak was coming from around that area..................................
Old Mar 25, 2006 | 08:56 AM
regularguy412's Avatar
Things to check: O2 sensor, AFM, TPS. You may be on the right track with the coolant temp sensor. The ECM may not know that the engine has warmed up, and therefore not going into closed loop.
Mike in AR
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
