15deg Adv, Code 26
15deg Adv, Code 26
So basically everything is back running good....... except now i got the CEL on....Ran it to work, and it came on....Im running 15 deg BTDC, checked the codes 26, running too rich....... how on earth can i run 15 deg BTDC and STILL run rich? at 15 deg its a WHOLE lot more peppy than at 10, at 10 its super doggy......... anyone wanna chime in? im thinking about going with a new Water Temp Sensor, see if that helps, only 21$ and if i remember correctly, when i put it back together, a coolant leak was coming from around that area..................................
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
