1 ton dually axle
Old Oct 26, 2008 | 09:52 AM
coma's Avatar
1 ton dually axle
does anyone know the WMS to WMS width of the toyota one ton dually axle?
also, would the inner tires fit outside the frame rails of a t100 or would the rails need to be narrowed? just wondering.
Old Oct 26, 2008 | 09:58 AM
Ezrider_92356's Avatar
if im not mistaking i belive they have different bolt patterns and the dualy rims are actually one rim
Old Oct 26, 2008 | 12:18 PM
Matt16's Avatar
A bit of a relevant hijack...
Does anyone know whether these axles were actually stronger than the regular Toy 8"? The one tonne truck I had was carbed (22R), had small tires and didn't have a low range (2wd), so its ability to dish out axle abuse was pretty limited.
Old Oct 26, 2008 | 03:49 PM
TrikeKid's Avatar
They were full float from 92 on, so they may have been stronger from that standpoint. I've seen some talk that the shafts aren't as beefy as the regular 8". They don't use the 6x5.5 bolt pattern like a 4wd Yota, but you can use regular front hubs to attain that if you know of someone that will make you an adapter to go from shaft to hub. I don't think they're different enough to bother with. Front Range Offroad makes a nice full float kit if that's what you're after.
Old Oct 26, 2008 | 04:47 PM
Matt16's Avatar
Just curious. I have yet to break even a CV axle, so I will not be upgrading my axles.
pickle6415
Apr 14, 2021 06:20 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
89hilux1
Sep 14, 2015 06:13 PM
theduck21
Sep 10, 2015 07:01 PM
May-39
Sep 6, 2015 01:05 PM
