xtra cab rear panel cargo nets
Old May 16, 2018 | 09:00 PM
Toyota4Low's Avatar
Anybody know how to pop the cargo nets off the back of the cab? I want to replace the elastic band on top so I can use them again.
Old May 17, 2018 | 03:11 PM
thefishguy77's Avatar
Hit the breaks real hard when you have something somewhat heavy on the shelf. At least that how my old picked one got removed.
Old May 20, 2018 | 09:15 AM
slacker's Avatar
you need to remove the panel .
on the back side of the panel you see the posts and the metal retainer clips .
I used a small die grinder to cut the metal clips off , then the nets come off as an assembly . you can repair or replace them from there , and re install them . I found the replacement clips from a local car parts store .
Old Jun 25, 2018 | 03:27 PM
Toyota4Low's Avatar
Awesome! Thanks! Looks like the previous owner had taken that off so it has the push pin things now. I will be rebuilding my carb tomorrow. May tackle that as well. Thank you!
jimbo74
10
Nov 2, 2017 03:53 AM
mbomberz1
Jul 12, 2014 08:00 PM
rdlsz24
May 26, 2008 04:29 PM
NRM
7
Apr 26, 2005 10:53 AM
