Xtra cab plastics. way to reinforce? they're brittle!
Old Feb 7, 2015 | 08:49 AM
jaysson_2012's Avatar
I found a pretty decent set of xtra cap plastics at the junkyard. But just like any other they are very britle and crack if you look at them too hard. I was wondering if anyone had any ideas how I could maybe reinforce them. Maybe rhino line the backside or something. I've been thinking there might be something I can do with fiberglass too but I don't know anything about it.
Old Feb 7, 2015 | 04:13 PM
slacker's Avatar
we sell replacements , way stronger then the flimsy originals . should last forever !
as far as reinforcing the originals .. good luck ! what ever you do , it will make the original thicker , and you may have fitment issues , IDK ? and I think the original plastic will still deteriorate
Old Feb 7, 2015 | 04:20 PM
Thanks for the heads up, I've been looking at yours for awhile. But I found these for $10. Also I didn't see the back either on your website.
Old Feb 7, 2015 | 05:01 PM
slacker's Avatar
yeah .. I would like to find the back piece .. so far no luck
I really don't know how to reinforce the originals , sorry !!! .. most stuff you do to the original plastics wont stick
maybe theres a product out there that will soften them up again ? Maguire's products ?
Old Feb 7, 2015 | 05:28 PM
bootscootboogie's Avatar
Make a mold of the original plastic pieces. Then put coat hanger wire in there like rebar and pour in some kinda crap? I'm onto something here
Old Feb 7, 2015 | 05:39 PM
Are you looking for one for a mold?
Old Feb 7, 2015 | 09:00 PM
nothingbetter's Avatar
Old plastic that's dry and brittle can't be saved. Over time the uv light does its thing and you're pooched. I got some from a parts truck like you did and had the same thing happen to me so I bought some of Slackers. Quality product as usual.
If you wanted to paint them to make them look all fancy, plastic is tricky to work with. Most paints won't stick to it unless its prepped using special products.
Old Feb 7, 2015 | 10:30 PM
highonpottery's Avatar
Old school trick might be spray expanding foam insulation
Old Feb 7, 2015 | 10:41 PM
Terrys87's Avatar
As far as painting interior pieces, I use Adhesion Promoter from your local parts store and you have to use interior paint. It has something in it that basically makes the paint more flexible. It works well on vinyl and plastic. Getting the pieces clean is the key thing to it.
All of the interior painted trucks I had seen in the past looked bad. It was done with normal paint and that is a no no. Stacey David used interior paint on Ted Nugents Bronco and that is how I come about to using it. As far as bringing old plastic back to life, really not much you can do about it.
Old Feb 8, 2015 | 03:46 PM
slacker's Avatar
I would if I had one ... but I really don't want to spend any cash , as I know it wont be a big seller , I doubt I will get my money back for the cost of the mould .. most people just "ryno line" the back wall , or carpet it .
jake_v
Aug 27, 2015 08:53 AM
Duppie007
Aug 25, 2015 11:51 PM
Backcountry411
Jul 24, 2015 08:06 AM
Robojd1
23
Jul 21, 2015 01:43 PM
Steezy96yota
Jul 6, 2015 10:00 AM
