window mechinsim
Old May 28, 2007 | 09:28 PM
simplypv's Avatar
window mechinsim
been trying to figure out whats wrong with my driver side window mech. the shaft that the handle (for roll the window down onto) moves around a bit, and it seems like the gears engage a bit, so the window will roll down and up just slightly, then it starts to skip teeth. cant really see if the gears themselves are stripped out, doesnt feel like it though. window can be pushed up or down and i dont like this. i want this window fixed!
my question is, can i replace the gear mechs. or does the door have to be replaced? i cant find any bolts to undo and remove the mech. any advice would be apperciated. thx!
Old May 28, 2007 | 09:33 PM
Tylercs's Avatar
The same thing happened to mine. The bushing that the shaft rides in had worn out allowing the gears to slip out of each other. I was able to make a new bushing with JB weld and an old nut but it only lasted 3-4 months until it also broke on me.
Old May 29, 2007 | 08:10 AM
michalik_piotr's Avatar
there are regulators on ebay for like $20.
LUV24BY's Avatar
Check This Out This is the place I bought my Window Regulators. $16 a piece and work great! They are easy to replace, once you have done it once, you will be able to do it the second time in half the time!
John
Old May 29, 2007 | 07:57 PM
simplypv's Avatar
cheers luv. thanks dude! hows az btw? im missin the weather!
RDubya
Feb 10, 2017 04:46 PM
PNW94Runner
Sep 29, 2015 02:55 PM
tazman1972
11
Sep 28, 2015 10:32 PM
punks_is_4x4
Sep 19, 2015 05:52 AM
mat
Sep 17, 2015 11:18 PM
