White smoke at idle..
Old Sep 16, 2010 | 04:49 PM
Uthro69's Avatar
So if you have seen other threads i just had the carb redone and it runs good hesitant when cold but alot of motors are but at idle or low rpm theres white smoke coming outta my exhaust.. If its burning oil its burning it to where i hardly notice and i am pretty sure its not coolant, on the air cleaner theres the piece that connects to your valve cover i forget what its called but its there to recycle air im seeing oil around the area leaking slowly, can the pcv be fault and not relieving pressure causing it to suck oil into the intake?
Old Sep 17, 2010 | 11:49 AM
94'wheeler's Avatar
White Smoke= Coolant
Blue Smoke= Oil
Black Smoke= Too much fuel/Carbon
Thats what I like to go off when chasing smoke issues, makes it easy to start pinpointing problem areas. Best of Luck!
Old Sep 17, 2010 | 11:54 AM
xxxtreme22r's Avatar
mine does this when it's less than like 60 degrees out, brand new rebuild, goes away after motor is warmed up and a little bit of driving, might be perfectly normal and just condensation burning off from inside the intake plenum and carb. Does yours go away? The reason why it would do it more at idle than when on the throttle is because engine vacuum is the highest at idle or when on the throttle and rapidly close the throttle.
FYI a slight rich fuel mixture will also cause what looks like white but really gray smoke as well. Way over rich will produce black.
Old Sep 17, 2010 | 04:37 PM
Uthro69's Avatar
yea i think it may just be a tad rich causing the grey smoke i am 85% sure that its notcoolant
Old Sep 17, 2010 | 08:17 PM
94'wheeler's Avatar
Good call. I go off of those for general troubleshooting. Never thought about exhaust moisture as the possible problem!
Old Sep 17, 2010 | 08:59 PM
toyota4x4907's Avatar
Heres how to tell the difference between burning coolant white smoke and condensation white smoke.
Burning coolant will linger in the air, its thicker looking and smells sweet and like anti-freeze.
Condensation will thin out, is a lighter looking white and will smell hot to nothing.
Old Sep 17, 2010 | 09:00 PM
Uthro69's Avatar
so if its white (grey) and smells like gas ... lol?call that running rich aye?
Old Sep 17, 2010 | 09:08 PM
what have the temperatures been like at night?
Does it do it ALL The time when idling or just after starting up after sitting for 3+ hours?
Old Sep 18, 2010 | 09:52 AM
Uthro69's Avatar
well i live in phoenix so static 100 degrees dry as all get up 99.98% of the time, side not i just replaced the pvc valve and put a new air filter in, be honest the white smoke is mainly idle but if im sitting at a light and i gas it or rev it up it spits out a cloud then it dissipates
Old Sep 18, 2010 | 10:44 AM
94'wheeler's Avatar
I'd say your a tad rich. I know that Arizona heat, very little moisture!
Old Sep 18, 2010 | 10:46 AM
94'wheeler's Avatar
For sure. My 1994 p/u did that, spewed burning coolant after about 15mins, its not hard to miss! Doesnt sound like thats OP's issue.
puddlepirate
Jul 30, 2016 06:29 PM
dzldust
7
Oct 6, 2015 05:39 AM
1985 4Runner
Sep 30, 2015 10:17 AM
charlie_fong
Sep 27, 2015 10:06 PM
Buckaroo_Banzai
Sep 24, 2015 07:26 AM
