What is this and should something be attached to the tip?
Old Feb 1, 2025 | 11:08 AM
Desert 85 pickup's Avatar
What is this and should something be attached to the tip? It looks like a hose should go there but I don’t see a lose hose and can’t find anything online.
Old Feb 1, 2025 | 12:01 PM
2ToyGuy's Avatar
It looks to me like the actuator for the cruise control. The device that operates the throttle to maintain the set speed. It should have vacuum from the throttle body directly to the connecor. There's a place on the throttle body that has 3 vacuum line connections. A line directly from one of those to the actuator is the key. Does that help at all?
Pat☺
Old Feb 1, 2025 | 01:38 PM
Pat☺
thank you! I think that may be it! I’ll take a look at the throttle body and see if I can get it connected.
Old Feb 2, 2025 | 01:07 PM
2ToyGuy's Avatar
Make sure the cable out the opposite end from the vacuum line goes to the throttle body. Same place the cable from the gas pedal goes. Make sure it's on the correct way, ie: it pulls the throttle open, just like the gas pedal does.
Good luck!
Pat☺
az_eaglescout_pilot
Aug 23, 2011 04:55 PM
87hillbillyoter
Apr 10, 2010 08:15 PM
reggie 00
Jan 14, 2009 09:19 AM
91 4Runner
Oct 12, 2006 12:12 AM
