what parts are needed for a rear brake job?
Old Mar 29, 2008 | 10:43 AM
88wildrunner's Avatar
i need new brake on the rear of my runner
does anyone have a parts lists of all the things i need to do a complete rear brake job and a guesstimate of the costs.
also ive never done a rear brake job (DRUM BRAKES) before i have done front disks though. is it pretty easy to figure out with the FSM?
Old Mar 29, 2008 | 01:53 PM
waskillywabbit's Avatar
and search are your friend.
Found this with a simple google of "Toyota drum brakes"
http://www.4x4wire.com/toyota/maintenance/rearbrakes/
Old Mar 29, 2008 | 03:45 PM
4runner Freak's Avatar
I think I still have a NEW set of springs(the rebuild kit) for an '85 rear if that is what you have.
EDIT: Nevermind, you have an '88. Probably different springs in the 10" drums.
Old Mar 30, 2008 | 04:13 PM
TrikeKid's Avatar
It was about $200 to replace everything but the backing plates on my rear axle. That's wheel cylinders, hardware (springs/pins/etc...), shoes and drums. Save yourself some pain and get the right tool for taking the springs off and putting them back on, doing it with vice grips can work, but usually ends in pain.
Old Mar 30, 2008 | 04:24 PM
machabees's Avatar
It can also end in the spring being flung all the way across the garage and a good 20 mins spent looking for the stupid thing.
Old Mar 30, 2008 | 08:49 PM
Sked's Avatar
Sorry to hyjack, but does anybody know if early wheel cylinders 8" will work on a late 10" drum system?
Old Mar 31, 2008 | 08:05 AM
jmazoso's Avatar
Been there done that. Only it was out on the driveway.
Old Apr 2, 2008 | 10:29 PM
XtraSlow_XtraCab's Avatar
The drums are probably still useable if you have them turned at a machine shop. That saves you... atleast 100 bucks. And yo can rebuild the wheel cylinders... you save 30-50 bucks easy that way. Whell cylinders are only comprised of about 3 or 4 parts.
Spring kits are cheap.
They DO have special tools for drum springs removal. A Hell of a lot easier and they save you time. One looks like a set of long pliers. There's an open end with a notch that rotates under the spring hook, grabs on, and allows you to pry them off. The other side is a dished flat head that you hook the spring hook on, while resting the tip on the spindle where the spring hook belongs, pull up, and the spring hook slides into place.
So get that plier looking tool for drum brakes, and there's a special screw-driver-looking tool for the other parts of the drum brakes.
Your last option is to get those parts, drive on down here to Vacaville and lemme do em for ya for 30 bucks! Or a case of beer, I'm not picky
All in all, it should only cost you about 100 bucks to redo both sides.
Aleeex_u
Jun 5, 2016 06:52 PM
voiddweller
19
May 2, 2016 09:10 PM
cchinny
Jun 25, 2015 08:11 PM
yamaha73
Jun 18, 2015 06:19 PM
HALMAN
Jun 14, 2002 09:02 PM
