What next?
Old Apr 7, 2007 | 09:27 AM
raymeg's Avatar
What next?
My `85 is running decent now.I have a few ?`s I was gonna see if you guys could answer.The truck seems to have good power through about the mid range of 3rd gear,after that she doesn`t feel as strong.Could this be due to the 34`s I`m running?What is the best start and cheapest for improving the sloppy steering.This thing shakes like hell around 40 mph.I don`t mind it that much,,but it would be nice to be able to keep it in the road without such a struggle.I`m glad to be putting some miles on her finally though.How strong is your motor while running the big tires?The motor does have a rebuild and a weber `34 set up.What did you guys do to improve upon these issues?Thanks
Old Apr 7, 2007 | 09:36 AM
4Crawler's Avatar
Proper gearing for that size tire would be a good idea, either 4.88s or 5.29s.
You can try to tighten up the drag link ends or rebuild them if needed, it that is the cause of the steering play.
Old Apr 7, 2007 | 12:13 PM
Sonofmayhem's Avatar
I would regear as 4crawler said. 4.88s or 5.29s. That will help with the larger than stock tires you run.
For the steering i would buy a hysteer kit from a popular vendor, tg, marlin, etc. Even just get an alignment if you dont want to spend the money on the hysteer. plus you have to buy the ifs box
