What gears...opinions
I am getting my 3'' lift installed this week, my 33's put on and my crossover steering ordered and installed in the next week or so. The next thing on the list is gears of some form.
Would you rather have t-case gears / doubler or diff gears with a rear locker and open up front?
Keep in mind these are both in the same price range because I have the auto trans so I have to get the Auto - gear driven t-case adapter, the doubler adapter, gears for one of the t-cases AND 2 good cores from my local junkyard to do the t-case / doubler set up.
Brandon
Brandon
Having an automatic transmission is going to make it more expensive and harder for you expense wise and with the extra parts needed to add duel cases. for now, i would recomend that you get diff gears first, i would recomend 4.88 or 5.29 gears, depending on if your truck is a daily driver or more for off road.
Brandon
Welding the rear aint that bad. Ive had it done on two trucks, and with the right tire pressure it BARELY barks around corners, its also cheap...
The 4.7 TG tc gears are AWESOME i love them. with 35s 4.10s and in low i can pull a car over a 4x4 without touching the gas
but with 5.29s it gets you like 15:1 over the 4.10s, if your truck sees street duty gear and lock first dont do the front till you get longs or a twinstick...
HIJACK: What is the *BRAND* people would recommend when one is considering gears?
1. Yukon Gear
2. ??
3. ??
Please help Hayes and I budget!!
Check this place out Hayes, it's a good source for lockers & gears:
Just Differentials - Toyota
John
1. Yukon Gear
2. ??
3. ??
John
