what is this? on a 84 22r carb
Old Oct 27, 2006 | 12:56 PM
FOCUSHERE's Avatar
im trying to figure out what this nipple on the top of my valve cover is and were both the red vaccum lines go
thanks
Old Oct 27, 2006 | 02:15 PM
herpestes's Avatar
The 1 on top of the valve cover goes to a fitting on top of the stock air cleaner cover.
Old Oct 27, 2006 | 04:31 PM
myyota's Avatar
The part on the carb is the outer vent control valve, it should be hooked up to the charcoal canister, it vents vapors from the carb to the charcoal canister. not sure about the lower fitting. my truck isn`t here, or i would go out and look.
I just looked at a vacuum diagram i have for my 85, the vent control valve is conected to the charcoal canister mounted down by the frame near the radiator, couldn`t find anything on the other conection.
Old Nov 24, 2006 | 07:33 PM
toyota_mdt_tech's Avatar
Originally Posted by myyota
...not sure about the lower fitting. my truck isn`t here, or i would go out and look....
That lower item is the "air suction valve" or diverter valve. It shuts off the air on decel into the manifold to prevent backfiring. I assume when disconnected, it defaults to "no air in manifold". It sucks filtered air from the air cleaner. Everybody already mentioned what all the other stuff is for.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
taraf
Sep 25, 2015 02:57 PM
