Valve Cover Gasket ?
Old Oct 5, 2015 | 04:51 AM
EVars's Avatar
I'm getting ready to put my valve cover back on. I have a new valve cover seal. Does the new valve cover gasket simply fit back inside the groove on the valve cover or is it recommended to add a little clean oil in the groove and on the gasket so that it seals better? Any suggestions or tips would be appreciated.
Old Oct 5, 2015 | 03:44 PM
Terrys87's Avatar
I install my gasket dry. I don't have problems with the valve cover gasket, but the half moon seals on the ends of the heads will be more of a problem. I use a little sealant on the half moons.
Old Oct 6, 2015 | 04:04 AM
EVars's Avatar
Thanks. I actually picked up a set of aluminum half moon billets from 22reperformance.com, so my troubles with the half moons leaking should be over.
live4soccer7
May 11, 2016 06:52 PM
Obmi
Oct 7, 2015 05:44 AM
dzldust
7
Oct 6, 2015 05:39 AM
Obmi
Oct 4, 2015 08:11 PM
alexcarey
Oct 4, 2015 09:56 AM
