Vacuum Disaster
Old Jul 6, 2010 | 08:53 AM
yotarunner87's Avatar
Vacuum Disaster
I have a 88 22re, a 82 22r and a 84 22r in a 4runner they all have one thing in common... SIX THOUSAND VACCUM LINES!
Is there any way to eliminate some or any of these and still keep the truck running okay?
Im more concerned about the 22r, the i understand what most of the lines do in the 22re.
Im having carb problems on both of the 22r's i just got them yesterday. I know i need new fuel lines for both of them and the choke is kinda messing with them.
the guy who had these trucks before me has screws, sticks, hose clamps and a ton of other junk plugging off a bunch of lines and looking at the FSM is like looking at algebra to me.
Not sure if the vaccum junk has anything to do with it but id like to get rid of it if possible.
Would i need a different carb to do this?
I know weber makes a 22r carb, are there any other good carbs out there?
I have been a fan of the site and have been coming here for info for a long time! thanks for the help!
Old Jul 6, 2010 | 09:58 AM
rsidner's Avatar
I would go with a Weber carb replacement.
Like this one: http://www.toyotacatalog.net/M1WebGe...A-8136AFD3FFDD
I hear a lot of good things about them and best of all, it will eliminate 95% of your vacuum lines!
Old Jul 7, 2010 | 12:09 AM
i found a diagram that shows minimal vaccum junk. i think im gonna try this before i swap the carb.Vacuum Disaster-22r-carb-vaccum-diag..jpg
i also read a ton about the weber carbs.
for a stock motor use 32/36
for any mods(cam, header, ect.) use 38
the 36 and 34 models are fake webers and are junk. out of probably a hundred articles only three that i read said they actually liked it and had no problems. they have junk gaskets and are just poorly made.
Old Jul 7, 2010 | 12:33 PM
8522recmess's Avatar
85 22 rec
i may be in the wrong area if so i apologize.help i have an 85 22 rec. ive been having problems with it since 99. no one where i live has been able to fix it. even toyota.its dumping raw fuel out the exhaust. im getting around 170 miles to a tank. ive replaced a ton of parts, including the ecu. it starts poorly and ildes great @ times and rough @ others.it will idle around 800 smoothly,then idle up to 1ooo or so roughly.ive replaced all the vacuum lines,took the fuel injection off and replaced all the gaskets,nuts,bolts,injectors,etc. had everyhting cleaned and resurfaced for even fit.egr new,tps new,yada yada yada. if anyone has suggestions please advise.im near the point of stopping.
kawazx636
Oct 6, 2021 03:03 PM
Steven.m.paulk
Jun 7, 2020 10:45 AM
zytra
Jan 24, 2019 03:16 PM
Ditch Doc
Oct 27, 2015 03:20 PM
zanzabar0
Oct 11, 2015 02:56 AM
