transmission wont come out
Old Oct 11, 2011 | 08:46 PM
runs-on-4's Avatar
my shift fork broke today so it was stuck in forth gear. so im taking the transmission out. but it wont seem to come out. all the bolts are undone and the bellhouse will come about 3/4 inch off the engine. but it just wont drop, what could be stopping it?
Old Oct 12, 2011 | 05:04 PM
rokblok's Avatar
Maybe the throw-out bearing crooked on the sleeve? If I recall, the shift fork is only "snapped" into place, so you may be able to work(force) the trans to seperate from the shift fork, if thats the case...
Old Oct 12, 2011 | 05:09 PM
evileyejones's Avatar
if its the 3. 0 engine, i had the same problem. took me a while to figure out the exhaust crossover pipe was catching it.
Old Oct 12, 2011 | 05:16 PM
Jkelley429's Avatar
make sure the starter is removed, that will catch on the engine block. while youve got it out you might wanna do a whole clutch kit.
Old Oct 12, 2011 | 09:08 PM
runs-on-4's Avatar
i finally got it out after awhile of using a pry bar. not sure if its the fork that just what a mechanic told me.
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
