Throttle position sensor
Old Feb 16, 2015 | 07:08 PM
theduck21's Avatar
Bought a 85 sr5 4x4 22re a few weeks ago. Guy told me it has a 94 motor with the 85 intake on it but needed the tps sensor to run so I bought it and now it will run but just for a second or two. I thought maybe the fuel pump but come to find out that its fine, the relay was bad though. Changed it out and now have fuel to the rail but still only runs for just a second, called the guy I got it from and he said the bracket (or butterfly etc) the tps bolts to was from the 94. Would that have anything to do with it only running for a moment? Tried a different mass air flow same thing, thing unplugged the mass air flow and still the same thing. Any ideas? Please help I want to drive this thing!
Old Feb 17, 2015 | 01:43 AM
Terrys87's Avatar
How is your timing? Are you getting fire to the plugs? Are your injectors firing? Make sure all hoses and cable are connected. The Air Flow Meter must be connected and no leaks in the air flow system. Seems to me Toyota did change to a different part number on the 92 an up TPS and that may be one of your issues.
Old Feb 17, 2015 | 02:42 AM
theduck21's Avatar
Everything is as it should be and for the split second that it runs it runs really smooth. I even took the the tps off then tried to crank it and still the same thing.
Old Mar 30, 2015 | 10:11 PM
samx227's Avatar
grounds?
Old Mar 31, 2015 | 02:26 AM
combatcarl's Avatar
COR? Circuit opening relay?
crammit442
7
Nov 29, 2017 12:30 PM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
