Are these hubs spinning correctly?
Old Jul 8, 2020 | 04:53 PM
Jakez's Avatar
1993 toyota pickup 22re 5SPD
With the front wheels jacked in the air and 4wd engaged and in reverse but front hubs Unlocked, if I spin the drivers wheel the passenger wheel spins (opposite direction). But if I spin the passenger wheel the drivers wheel (nor cv) doesn't spin at all? With the hubs Locked spinning the drivers side will spin the passenger and spinning passenger will spin the drivers side.. Also, when I locked the fronts the rear driveshaft didn't move or try to move the rear wheels at all...?
Old Jul 8, 2020 | 08:25 PM
millball's Avatar
Sounds like the drivers hub is not unlocking.
Old Jul 9, 2020 | 11:36 AM
Jakez's Avatar
Maybe I should I try holding the drivers wheel still while spinning the passenger wheel? Possible it was just internal friction making it move?
Old Jul 9, 2020 | 12:16 PM
millball's Avatar
If you've got IFS, you should be able to try and hold that sides half shaft while turning the wheel with the hub supposedly unlocked.
gottadog
Nov 4, 2012 03:02 PM
4runner dude
Jan 10, 2011 12:46 PM
jrdefran
Oct 6, 2006 08:05 PM
Tack427
Apr 20, 2006 04:19 AM
