Thermostat Sensor what is it called on top of the tstat housing
Old Jul 2, 2007 | 07:36 PM
slinkyeleven's Avatar
This is a single wire sensor, what is it called and what is it used for
Thanks
David
Old Jul 2, 2007 | 07:47 PM
locked stock 84's Avatar
pics would help but I would guess that is the coolant temp sensor/ sending unit.
Old Jul 2, 2007 | 07:59 PM
SoCal4Running's Avatar
It is I believe 1 of 3 different temp sending units. That one I think if for the computer.
Old Jul 3, 2007 | 04:23 AM
Yoda's Avatar
I know its not the main computer sensor. The gauge and comp sensor are in the manidold. The one on top of our tstat has had the wire broke off for 7 years
Old Jul 3, 2007 | 08:57 PM
The wire that is located on the forward p/s of the engine closest to center is the coolant temp sensor for the ecu. Next to it is the cold start injector sensor. Near cyl #3 on the p/s of the valve cover in the head is the guage sending unit. I am not sure what the one on top of the thermostat housing is used for nor can I find any wiring on it. Is it a thermo switch that is only used on automatic transmissions. The 85 4x4 is a FI 5 speed?
David
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
Iceman4193
Jul 15, 2015 04:48 PM
cars-guy
Jul 11, 2015 07:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
