Thermostat Sensor what is it called on top of the tstat housing
The wire that is located on the forward p/s of the engine closest to center is the coolant temp sensor for the ecu. Next to it is the cold start injector sensor. Near cyl #3 on the p/s of the valve cover in the head is the guage sending unit. I am not sure what the one on top of the thermostat housing is used for nor can I find any wiring on it. Is it a thermo switch that is only used on automatic transmissions. The 85 4x4 is a FI 5 speed?
David
David
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
Iceman4193
Jul 15, 2015 04:48 PM
Poncho0206
Jul 10, 2015 06:21 PM
