Thanks to you all!!
Old May 15, 2016 | 05:17 PM
peterbilt6905's Avatar
Thanks to you all!!
I joined yodatech 2-3 months ago when I picked up a 84 4runner.it's in pretty decent shape for being here in Nebraska, no rot just a little rust here and there. Its a little bit of a project. Nothing major just some electrical and mechanical issues.
One of many previous owners had done there little trick hack jobs to the electrical and the smog equipment. It has a remanufactured head and new timing chain, cover and water pump. Also has a 38 Weber that was all out of wack. Someone yanked out all the vacuum lines and assumed that now it's "de smogged". The Weber adapter plate was leaking horribly even with what appears to be a whole tube of rvt gasket sealer. The dizzy didn't work properly, corroded and gumed up. I sure not having a oil dipstick didn't help. The shaft that the rotor slides over was almost rounded off.
Pretty much learning as I go.
Here is what I have done...
New LCE spiral adapter
Egr block off plates, the one for the manifold I put on a barb fitting for the pcv value
Manifold plugs
New dizzy from LCE, ouch!!
94amp GM alternator and bracket
GM style ignition
Now the little Yoda is running better, smoother and stronger!!
Still need to adjust timing a little. It's right at 4 btdc with the vacuum disconnected and pluged. Will adjust the carb as I go. All in all its been a fun little project.
I just want to say thank you yodatechers!!! Each and everyone of you. I searched posts old and new and I can't remember all the names but you all helped in one way or another.
Thanks!!
Old May 15, 2016 | 10:00 PM
Terrys87's Avatar
Glad to see the site help you get another yota back into shape and on the road. Will be looking forward to seeing some pictures of it. Not many 84s out there.
Old May 16, 2016 | 06:10 PM
Here is a picture of my 84. I'll post more as I go.
This is when i brought the runner home.
Old May 17, 2016 | 04:12 AM
The cluttered engine bay when I started
What i started with
No more clutter. Pretty basic
A/c and smog parts removed
Notice the little black box on the frint cross bar above the bucket. Its a hide a key bix with the original key.itsa little wore out.
So this is where I'm at with this runner. Ist actually kinda fun.
Old May 17, 2016 | 07:56 AM
Lonnie-S's Avatar
I'd say your engine and engine compartment look darned good. You 'oughta see the grime on the (early) '84 I just picked up. I also see some nice things on your very clean engine like a nice breather on the valve cover, and a pressure (?) gauge in your fuel line.
Just keep at it and have fun!
Cheers,
wolfpackfan33
Mar 3, 2016 01:45 AM
bigmumbles69
Feb 29, 2016 08:05 AM
Tkeehr11
Feb 21, 2016 05:57 AM
ladybugRC
Feb 18, 2016 04:50 AM
FinallyOffRoad
Feb 17, 2016 03:06 PM
