Thanks Budbuilt!
Old Jun 18, 2008 | 03:08 PM
86tuning's Avatar
Thanks Budbuilt!
I got my crossmember yesterday. 84, single. Powdercoated black. Super high quality pieces. Almost too nice to bolt under my truck.
Today I put it on. Super easy to install, with all hardware including low profile magnetic drainplug and gasket. I only lost a few drops of gear oil while swapping the drainplug. I like the extra screws and the allen key.
I used some new 1/2" ID washers for the outer mounting bolts.
Now my stock rock-magnet trans crossmember is in the recycle pile.
Thanks!
For those who don't have one already, these pieces are highly recommended.
Old Jun 19, 2008 | 11:43 AM
Trustyrusty's Avatar
Do you have dual T-cases or just a stock setup? Id like the crossmember but I dont know if it works with the stock setup..
Old Jun 19, 2008 | 11:49 AM
86tuning's Avatar
I have the single case xmember. Same as pictured below, but black.
http://www.budbuilt.com/new/single_cross_members.html
And yes, it works fine with a stock setup. I got a lot more ground clearance, plus a partially flat bottom for sliding over stumps or rocks.
Highly recommended. And a good price too, at only $179 + shipping. Powdercoating was extra, but you can always paint it yourself too.
Old Jun 19, 2008 | 12:29 PM
Oatmeal's Avatar
I've had mine (also a single case version) for over 5 yrs now.....bought it when he was still relatively unheard of, and it has held up to many miles of hard offroading! Just a tip: make sure and use antisieze on the allen screws, it's easy to strip out the heads when they've been through the elements and refuse to come loose! -----------Hans
Old Jun 19, 2008 | 12:57 PM
86tuning's Avatar
Yeah, I did use antiseize for all the bolts, including the frame mounting bolts. They do salt the roads around here in the winter too!
Old Jun 19, 2008 | 01:53 PM
85toy's Avatar
sounds cool thats the only thing ive found to complain about on my truck the stock crossmember.
Fergie
Feb 14, 2007 01:35 PM
86Original
Feb 14, 2007 06:45 AM
bamachem
372
Jun 14, 2006 09:17 AM
934rnr
Aug 29, 2005 05:55 PM
Firefyter-Emt
12
Jun 10, 2003 07:57 PM
