temp gage semi broke
Old Sep 4, 2008 | 10:36 AM
nomiss05's Avatar
my temp guage will be on then just fall abck down to the rest post. i dunno if there is a sensor to check or is there is a way to see if its the guage. any ideas?
Old Sep 4, 2008 | 11:20 AM
4Crawler's Avatar
The Factory Service Manual has test procedures for tboth the gauge and the sender. Might check that the wire is plugged securely into the sender, I had a problem with my oil pressure gauge dropping to 0 every now and then and it was a bad connector on the sender. I rebent the metal inside the connector shell to make it fit tighter and it has been fine since.
Old Sep 4, 2008 | 11:24 AM
nomiss05's Avatar
i have the haynes manual.. is that the one that has it? where is the sender located?
Old Sep 10, 2008 | 05:59 AM
pcmentor's Avatar
There's a couple temp senders on the engine. Check each one's connector. There are at least 3 thermo sender/sensors on my 85 22re.
Here's an 1985 Service Manual
Right click on this link and choose save target
http://www.ncttora.com/fsm/1985/1985FSM.pdf
Obmi
Oct 30, 2015 04:27 PM
puddlepirate
Sep 29, 2015 08:02 PM
Matthew Perez
Sep 28, 2015 05:43 PM
rmill05
Sep 27, 2015 01:43 PM
mtrdrms
Sep 26, 2015 07:12 AM
