Tacoma wheels on an 84 Pickup?
Will Tacoma wheels (like the one in the pic) fit on an 84 Pickup? Far as I know the bolt pattern is the same but I'm wondering about the center hole.
Thank you
Thank you
My resource for a 2004 Tacoma 2WD wheel shows the center bore to be 67mm on that wheel and the bolt pattern to be 5 X 114.3mm. Check out this link for more info.
https://www.wheel-size.com/size/toyota/tacoma/2004/
The wheels will fit no problem, I had 3rd gen 4Runner wheels on my 85 Xtra-Cab but, the back spacing on Taco-Runner wheels is too deep which narrows the track too much so use wheel spacers and get to tracking wider on OEM rims.
Thank you
