Stock driveshaft alternatives!?! or cough up 300 to fix?
Old Oct 19, 2010 | 12:24 AM
85ghettorunner's Avatar
I have a 1985 4-runner, stock suspension. Driven daily on streets/freeways for work and occasionally off-road/camping/dunes/etc.
My rear driveshaft just started vibrating again(had both rear u-joints replaced less than 1000 miles ago, but the vibration JUST came back). I figured it was crappy replacement joints but i guess i was wrong.
Long story short, removed driveshaft and took to reputable driveshaft shop. He said it would cost 300 to replace the "slip joint"(the part that telescopes) as it is worn and the cause of the vibration. Is this reasonable? Do any other shafts fit the rear of my 85 4 runner? Or should i just cough up the 300 bucks?
Old Oct 19, 2010 | 12:48 AM
SpecialScottie's Avatar
Pick one up front the junkyard. Any driveshaft from an 84-89 4runner with the same engine and tranny should work
Old Oct 19, 2010 | 04:22 AM
Etype R's Avatar
for $300 you can get a heavy wall custom length rear drive shaft from Davez offroad performance.... Your drive shaft guy is asking a bit much, as I doubt it would be of the quality from Davez or the strength. I would be looking at junk yards as well. Also check craigslist for 4runners being parted out locally.
Old Oct 20, 2010 | 01:43 AM
TinMan's Avatar
I got a good rear drive shaft out of an 87 pick up I can send you. $50.00 plus shipping.
They are right, the drive shafts from TG are cheaper than you were quoted to fix yours.
Later
Old Oct 21, 2010 | 08:26 AM
Thank you guys SO MUCH for the replies!
Will any truck driveshafts fit directly into my 85 4runner? Or just driveshafts from other 4 runners?
Thanks again for the replies.
Old Oct 21, 2010 | 04:51 PM
TinMan's Avatar
I will measure the drive shaft on my runner and also the one out of the 87 pickup and let you know. I believe they are the same length and flange, I think the drive shaft out of the 87 may be a heavier duty shaft. I will let you know tomorrow.
Old Oct 21, 2010 | 05:57 PM
TOYOTAPARTS's Avatar
drive shaft davez off road
truck and runner will work: Edit
Old Oct 21, 2010 | 06:02 PM
waskillywabbit's Avatar
Friend of mine's driveshaft was the same way, the slip spline was worn out. I had 5 or 6 laying around so he found one the same length and swapped them out. Fixed. Compared to a dshaft with a good spline you can really tell the difference visually and in the ride.
:wabbit2:
Hey Dave!
Old Oct 22, 2010 | 11:42 PM
peow130's Avatar
This thread makes me want to go check mine out.
Mine vibrates like no other at 60+mph//
Old Oct 23, 2010 | 06:13 PM
TinMan's Avatar
I measured the drive shaft out of the 87 standard cab, standard bed, 4x4 and the drive shaft out of the 85 4runner this morning. They both measure the same.
I took some pics of the measurements but they did not save on my phone. I'll do it again tomorrow.
The front yoke on the 87 looks to be a little heavier.
I am not doubting Mr. Davez at all. The drive shaft that came out of the 87 could have been the wrong one to start with. Who knows.
You don't want the one out of the 87 though, it is dented pretty good.
Later
Old Oct 31, 2010 | 12:42 PM
You may be right, I ran into this a few years ago and found the truck was too long, but I didnt know which truck it was from. The wheel base between the 1st gen 4 runner and 2nd gen pu std cab short bed is the same so the d/s may be the same.
young buck
18
Aug 27, 2018 02:40 PM
redneck17
Oct 29, 2015 09:09 PM
coffey50
Jul 28, 2015 10:55 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
msane99
Jul 17, 2015 10:13 AM
