Steering Gearbox... $1409.78
Old Jan 31, 2011 | 12:24 PM
Uthro69's Avatar
So went to the stealership, having officially declared them that term, they say my gearbox on my 84 toyota pickup is going out, causing my bump in the wheel feeling when im trying to turn. My question is, can i go another route other then a junkyard piece?
Is there a rebuild kit? should i look into hy-steer?
Just looking for options cause i Refuse to spend almost 1500 bucks on a little gear box ...
Thanks
P.S. Part number is 45310-35111
Old Jan 31, 2011 | 12:29 PM
kpbigdaddy's Avatar
I ran into this on an 87 once and it turned out o be a balljoint issue....Might be easier to check this.
Old Jan 31, 2011 | 12:36 PM
waskillywabbit's Avatar
You can buy these used all day long online for under $100. Folks doing high steer throw them away. I've thrown away dozens.
:wabbit2:
Old Jan 31, 2011 | 12:47 PM
ScottyC's Avatar
I have one. $50 + shipping and its yours. PM me or call me. 970-420-4198
Old Jan 31, 2011 | 12:48 PM
Uthro69's Avatar
ill pm you im gonna check into my ball joints etc to make sure, thank you again
Old Jan 31, 2011 | 01:13 PM
DeathCougar's Avatar
Lemme know when you find those ball joints on an 84 Toyota solid front axle
Old Jan 31, 2011 | 01:18 PM
Uthro69's Avatar
lol good point, ive been sick man god. , pm inc may as well get that box while its here, anyone know if they can be rebuilt?
Old Jan 31, 2011 | 01:23 PM
kpbigdaddy's Avatar
solid axle still has the sockets that I have seen stick .....especially in sandy areas.but true no "ball joints"
Old Jan 31, 2011 | 01:30 PM
4Crawler's Avatar
Doubt it is the steering box, likely something worn out in the linkage. Check the rubber rag joint and u-joints at the ends of the steering shaft, and the play in the drag link and then the tie rod ends and knuckle bearings in the axle.
See if you can duplicate the "bump" with the front tires in the air, turning back and forth. If not, see if on the ground works. Then poke around underneath and follow the linkage motion and see where you get motion on one part and no motion on the next part of the linkage. That would be a likely source of the play.
Old Jan 31, 2011 | 01:31 PM
Uthro69's Avatar
well that rubber link between the shaft and the gear box is worn out, that part its around 350 bucks from the dealership but he says its most likely the gear box thats worn
Old Jan 31, 2011 | 02:20 PM
snobdds's Avatar
I keep getting the feeling that you want it to be the steering box because the dealership says it is. I hope you can see through their sales pitch...
Old Jan 31, 2011 | 02:21 PM
Uthro69's Avatar
why in gods name would i want the stealership to be right lol? im just gathering intel at this point im gonna put the truck on some stands and playing around see if i can pinpoint it
Old Jan 31, 2011 | 02:29 PM
Least helpful post ever.
You think the dealer is just making it up so they can sell a $1400 steering box? You think the dealer is so Naive they would actually believe someone would pay $1400 for a steering box?
Old Jan 31, 2011 | 03:08 PM
snobdds's Avatar
And yes, I do think the dealer thinks people are that naive to pay $1400 for a steering box. Happens everyday. Parts guys and service writers at dealerships work off commission! It's like fishing...all you need is one to bite!
Plus he said the rubber link in his steering is bad, but the dealer keeps insisting it's the steering box?
I stand by my comment that it's a sales pitch.
Old Jan 31, 2011 | 03:38 PM
kevtek's Avatar
I think it might have more to do that mechanics work at dealerships, not technicians. Mechanics do not diagnose vehicles, they keep replacing parts until the problems fixed.
Old Jan 31, 2011 | 08:15 PM
Etype R's Avatar
I check prices at the dealership on parts all the time. But a lot of stuff they have priced way to high, so parts store it is.
rebuilt steering box is under 400 at a parts store. And the rag joint, under 20.
http://www.oreillyauto.com/site/c/de...0254&ppt=C0203
Old Feb 5, 2011 | 07:03 PM
77lubr's Avatar
I know a handful of what you call "mechanics that work at dealerships" who would take serious offense to that statement. You may have had bad luck in the past, but a good dealership tech can and regularly does diagnose vehicles.
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
gentry
Sep 28, 2015 06:16 AM
