Steering box problems
Old Jun 3, 2009 | 12:31 PM
mainePW's Avatar
Exclamation Steering box problems
I aquired a used '85 non-IFS box from a salvage yard- seemed to be in good shape, no visible leaks. Flushed it out with the proper ATF, done with the front tires off the ground, using the starter to crank the engine briefly as I cycled the steering lock to lock while adding fluid periodically to keep the resevoir up. Went for a drive, found it pulls left- let go of the wheel, and you're at full left lock real quick. I jacked the front axle off the ground again, started up- same thing, steering wheel turns all by itself at idle. I do have power steering in both directions, no unusual noise or leaks. I assume I'll have to rebuild the box- haven't found any rebuild info on the push-pull type box. Anyone know of a writeup on this box- is it similar to the IFS internally?
Old Jun 3, 2009 | 01:13 PM
83's Avatar
83
I know when you take a steering box off you've got to mark the shaft so you know where center is. Are you sure the gears in the box think that straight ahead is the same as where the rest of your truck thinks it is?
I'll be very curious because I've got a power steering set-up I'll be installing on my truck soon and I didn't mark anything when I took it off the donor truck.
Old Jun 3, 2009 | 03:33 PM
mainePW's Avatar
When I set the steering up, I found the number of turns lock-to-lock, then came back 1/2 way when I mounted the Pitman arm. In theory, it should be centered. I'm getting full power assist to the left- don't want to take your hands off the wheel in traffic! Looks like a port is either closed or open when it shouldn't be. The 1st Gen IFS box looks VERY similar to my box except for the long sector shaft housing, which is why I'm wondering if the internals aren't pretty much the same.
Old Jun 3, 2009 | 04:12 PM
4Crawler's Avatar
There are, or at least should be, alignment marks on the sector shaft and pitman arm:
http://www.4crawler.com/4x4/CheapTri...html#Alignment
Old Jun 3, 2009 | 04:47 PM
dropzone's Avatar
Fossilized
the IFS box mounts entirely different..if you go that route might as well go full high steer but you will need about 3" of lift...
Originally Posted by waskillywabbit
The IFS box mount is pretty simple. Cut the fender well so you can easily access the PS box area like shown in my pictures posted already and then push the box all the way forward until it is on the core. Angle it so the holes line up on the frame in the center and then test fit your mounting plates. Tack weld and test fit again to make sure the pitman arm clears and weld out.
what you don't want to have happen when you install your high steer:
Originally Posted by 98taco4x
oh and make sure that your drag link clears your tierod.
Cause you don't want this.
Last edited by dropzone; Jun 3, 2009 at 04:50 PM. Reason: link I posted was dead, so deleted
Old Jun 4, 2009 | 06:38 AM
EWilson's Avatar
So what if you do have that problem?
It does hit and I was wondering if there's any way to fix that without having to re-mount it or get new springs.
Maybe a pitman arm with a little less drop???
Old Jun 4, 2009 | 07:12 AM
mainePW's Avatar
In my case, the Pitman arm position doesn't appear to influence the leftward action- I tried cranking in various amounts rightward bias to see if the box would center with the tires off the ground, but it keeps steering left- like it's owned by Obama. At idle, the assist is not sufficient to turn the tires when they're on the ground. There is assist to the right, just not as much as to the left.
With respect to the IFS problem mentioned above, I have seen either All-Pro Offroad or Trail Gear (can't remember which) markets a flat Pitman arm that might solve the problem.
rushw
Jul 18, 2015 01:46 PM
kyletbert
Jul 17, 2015 11:39 AM
voiddweller
Jul 15, 2015 03:56 PM
crashburnoveride
Jul 10, 2015 06:39 AM
