Steering box dead?
Old Nov 13, 2011 | 01:58 PM
slowngreen's Avatar
Steering box dead?
Hey guys. I have a High Steer kit with a IFS box. Last few times Ive taken my truck out, it seems to take alot to turn it if Im not moving. Fluid is fine, no leaks either.
I broke the passenger side birf the other day and after I got unstuck and driving again, I can turn all the way to the right but only maybe a 1/4 of the way past center to the left now. Fluid is still good. I see no binding any where either.
Is the pump probably just shot? I was thinking of going to hydro assist soon, but if the pump is shot I'll need to replace is first, but wanted to see what you guys have to say first.
Old Nov 13, 2011 | 07:20 PM
Duke70's Avatar
It sounds like you might have bent your Steering Stabilizer. I would disconnect it to see if that is what has happened. With it turning all the way to the right and not turning to the left sounds like that could be your issue. I have had this happen to me and everything looked good like your saying but I found out that the Steering Stabilizer was messed up after taking it off.
Old Nov 14, 2011 | 08:44 AM
slowngreen's Avatar
Should have said, I dont have a stabilizer. I found a good deal on another box so I bought it. I'll make sure it works when it gets here and that its not something else messed up, then maybe get into the assist setup.
4x4-runner
Apr 18, 2017 09:08 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
delmert
Sep 30, 2015 04:34 PM
zombie_stomp
Aug 17, 2015 05:29 PM
basfire
Aug 14, 2015 07:58 PM
