steering arm
Old Feb 21, 2007 | 06:19 AM
Bdog's Avatar
steering arm
The p/p arm on my stock runner has a popping noise coming from it when I turn the wheel a bit. Is there any aftermarket part or is it gonna be a toyota part. No it is not getting Hi-steer right now! Thanks gents!
Bdog
Old Feb 21, 2007 | 07:40 AM
4Crawler's Avatar
Likely the drag link ends are loose or worn. Try pulling that apart and clean/grease/adjust them. You can shim up the socket ends tighter if they are adjusted to the max or you can get a rebuild kit for the stock drag link. There are also aftermarket dropped drag links available if you have a lift.
Old Feb 24, 2007 | 07:17 AM
Bdog's Avatar
where ?
where can I find that rebuild kit?
Old Feb 24, 2007 | 07:21 AM
4Crawler's Avatar
Toyota parts counter would be a good place to start, places like NAPA might have them, or I know NWOR carries a kit, possibly Downey Offroad and some other possible places:
http://www.4crawler.com/4x4/index.shtml#VendorLinks
Old Feb 24, 2007 | 07:32 AM
deserttoy84's Avatar
go toyota bump steer!!
choppe777
May 16, 2016 08:00 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
128keaton
Sep 3, 2015 05:09 PM
I8URSVT
Sep 3, 2015 11:42 AM
